electrical fault??
Old Jan 21, 2011 | 09:17 PM
nm_coolj's Avatar
nm_coolj
Default electrical fault??
Iv got an MK5 fiesta ghia 2000. Everytime i start the car it takes approx 5 seconds for the dials and mileage display on the dash to kick in.
Iv aslso notice if i try to drive before the display kicks in it runs very rough.
Any ideas on what could be wrong or where i need to start????
Old Jan 22, 2011 | 10:57 AM
martysmartie's Avatar
martysmartie
Sounds strange, the dials perform a "Sweep" when ignition is switched on if the battery is discharged but not what you have. Check the obvious battery earth connections are clean and not corroded first.
Martin
Old Jan 22, 2011 | 11:11 AM
Phil2002's Avatar
Phil2002
speak to bba reman it sounds like it could be a problem with the clock set.
www.bba-reman.com
they will be able to repair your clock set if at fault.
hope this helps
Phil
Old Feb 17, 2011 | 02:03 PM
nm_coolj's Avatar
nm_coolj
HI cheers for the replies ppl.
Just thought ill add abit more info about the problem.
It starts 1sttime all the time but the display and dials take around 20 seconds to kick in. It drives fine straight away but if I stall thats when the problem starts.
After a stall it takes abit longer to fire up or wont fire up straight away. Than it will run realy rough and feels like its gonna cut out until the dials and display kicks in than it back to normal again.
The other day it had a realy wierd thing happen after a stall it didint fire up straight away, Second time all the dials went all the way across than came back than it started on 3rd attempt.
I also noticed that mileage counter got reset this time.
It almost feels like the ecu gets reset or somthing wenever it stalls so needs some time to get back to normal.
Any ideas now???
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
