51 ford mondeo mk3 central locking probleom
Old Jan 13, 2011 | 06:23 PM
oldskoolford86cabbie's Avatar
Default 51 ford mondeo mk3 central locking probleom
when operating the central locking from the remote the car unlocks fine but wont lock again unless u do it 8 or 9 times i have replaced the batteries in the fob and this has made no diffrence the lock engages but then unlocks again this happens on all the doors not just 1 if i drive the car somewhere and then operate the remote central locking it works fine......please any help will be appreciated its pissing me rite off
Old Jan 13, 2011 | 06:39 PM
Chaz888's Avatar
Chaz888
dose it only screw up at home maybe a signal problem ?
Old Jan 13, 2011 | 07:45 PM
martysmartie's Avatar
martysmartie
Could well be a classic problem that being that one of the master locks, I.E driver or passenger door is "Sticky" and so when the pulse times out one of the locks is "Stuck in the middle" so it reverts to the state it was I.E open in your case. The mechanism/lock simply needs lubeing to sort this.
Martin
Old Jan 13, 2011 | 11:20 PM
Cheers will try that Thanks
Old Jan 15, 2011 | 09:09 PM
I have tryd the wd40 on both front cental locking motor conections which were damp water leaking in then the remote central locking will work once i have messed around with it but leave the car for 20-30 mins then it will stop working it isnt a signal problem unlocks fine but i also found that the car will remote lock with the passenger door open so dose that mean the passenger door motor is at fault which is causeing the system to think the doors ajar so trying to lock then unlocking Thanks Alex
Old Jan 16, 2011 | 02:48 PM
martysmartie
The doors should not lock at all with either the driver or passenger door open, it still sounds like the problem I mention, it's not the connections that are the problem it's the lock/mechanism itself on the door, lube this.
It sounds as if the passenger door is the problem, disconnect the connector for this lock and then try locking/unlocking if this works then it's defo the passenger lock/mechanism etc thats the problem!
Martin
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
