51 reg Escort 1.8d van dodgy starting problem Help Please!!!!!!!
Old Jan 12, 2011 | 06:48 PM
Luther-The-Escort-Van's Avatar
Default 51 reg Escort 1.8d van dodgy starting problem Help Please!!!!!!!
Hello all!
I drove to the gym tonight about a 3mile drive, did my gym session, came out, got in the van and no go!
All ignition lights are lit up but no glow plug illumination on the dash.
Immideately I thought its a sticky starter.
Engine still just warm so 3 of us tried pushing it to push start it and would it fuck go!
So phoned me good ol' dad for a tow start and as soon as he arrived I tried it one last time and glow plug light lit up and vrooom it dived into life! Mother fucker!
Drove home, got on drive, turned it off and it fired up again no probs.
Left it an hour or so and same prob again.
Sat there thinking of doing a Bazil Faulty on its ass and noticed even when the keys are out of the ignition, the air bag light, battery light and handbrake light are ever so slightly illuminated (could only see as it's dark out).
I have only owned the van about 6 weeks but since I got it the battery light has been permanently on but the battery shows 12.5 volts with engine not running and over 14 volts with the engine running so its defo charging.
Any info would be massively appriciated!!!!
Many thanks in advance, John.
Old Jan 16, 2011 | 06:08 PM
matcossy's Avatar
matcossy
u need a auto sparki m8,,,dont mess with electrics
Old Jan 17, 2011 | 09:05 PM
cabriolet's Avatar
cabriolet
does the pats light flash if yes check the loom that runs above the radiator itll b worn through
Old Jan 17, 2011 | 09:24 PM
Escow-Van's Avatar
Escow-Van
I had an electrical problem with starting my van, but it would bump start ok. Couldn't work it out after chasing the fault around the van and eventually took it to the garage, they replaced the fuse board and it was sorted. Apparently it is quite a common fault on the escort for the fuseboard PCB to pop.
If you can get the fuseboard out without too much drama it might be worth a look for signs of damage.
Vincereese
Aug 16, 2015 06:38 PM
druidgetafix
Aug 15, 2015 10:22 AM
vdubo7
Aug 2, 2015 08:17 PM
muz
Aug 1, 2015 06:48 AM
