Sierra Cosworth 2wd thermostat - HELP!
Just sorting out the cooling system on my 3 door. The thermostat was missing so got a new one plus the rubber ring and gasket. Im guessing that as the stat is loose in the housing that there should be a circlip or something to retain it? -
As said, stat kits should have the clip in, been used since 1971!!, and also there should be a seal that goes in the housing first, then stat then clip that engages in the groove.
If you get stuck for one, drop me a pm, as I have some spare, can soon bung one in the post FOC for you.
Many thanks for the offer. Managed to get one from my local Ford dealer, not in stock but they got it the same day! Its part no.0242120 and was about 2 quid. Pretty good service for a 25 year old car, though I guess it must fit some later stuff as well.
charliecosworth
19-08-2015 02:00 PM
155lee
14-08-2015 11:21 AM
