focus st help please
Old Jan 6, 2011 | 06:31 PM
lmmrst's Avatar
lmmrst
Unhappy focus st help please
hi there have just started to have a problem with my 06 plate 2.5 focus st !! a squeeking noise started the other day when the engine was running and when i switched it off theres a hissing air leak noise !!anyway i noticed that the plastic breather pipe on the front of the engine was split so ive replaced that with a new rubber version !!!aahhhhhh noise still there so ive had another look 2nite and found that there is a massive vacum being created in the motor !! if i remove the oil fill cap or the breather the vacum is released and the noise goes away !! i just wonderd if anyone eles has come across this could it be the pcv playing up help please
Old Jan 6, 2011 | 06:34 PM
Tank Mike's Avatar
Tank Mike
Yes, you need to change the oil filter housing. very easy job. has the breather built into it
Old Jan 6, 2011 | 06:42 PM
RichieST's Avatar
RichieST
As above, oil filter housing diaphragm has split, really common fault on them!
Old Jan 6, 2011 | 07:38 PM
lmmrst's Avatar
lmmrst
cool thanks guys !!
Old Jan 6, 2011 | 08:59 PM
RIK.'s Avatar
RIK.
Newer type are modified from the one you have fitted and shouldnt happen again !!
Old May 10, 2013 | 08:23 PM
S111YST's Avatar
S111YST
Default Oil diaphragm noise
Hi. Have had the same problems with my 06 st. Found the info on hear very helpful. oil diaphragm has gone £130 + vat from ford next day
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
