Rear disc conversion help.
Old Jan 6, 2011 | 05:15 PM
Biddle1's Avatar
Biddle1
Default Rear disc conversion help.
Hello. I bought a project off a friend and it's a 1996 escort si. He had a rs2000 rear beam fitted to it and I've tried to put it through it's MOT today and it failed on rear brake efficiency. The tester said it was the master cylinder at fault and it wasn't designed for rear discs?
Can I just change the reducers that are attached to the master cylinder?
Old Jan 9, 2011 | 05:01 PM
Ryoishikawa's Avatar
Ryoishikawa
i put rear discs on mine left the same master cylinder on and worked rite away. check the hoses
yatta
May 21, 2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Tony W
Sep 9, 2015 12:08 PM
rsturbo27
Sep 5, 2015 05:08 PM
cossirob
Sep 3, 2015 09:17 PM
