mk2 rs blowing oil
Old Jan 2, 2011 | 07:56 PM
crock's Avatar
crock
Default mk2 rs blowing oil
my mk2 rs2000 is blowing oil out of the dipstick housing, any ideas why??????????? and what would be the best fix
Old Jan 2, 2011 | 07:57 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Blocked crankcase breather?
Old Jan 3, 2011 | 03:32 PM
Excess crank case pressure, as above check breather system is clear, then do a compression test.
Old Jan 4, 2011 | 05:26 PM
crock's Avatar
crock
were abouts is the crankshaft breather on the engine,and how do you clean it,thanks
Old Jan 4, 2011 | 05:33 PM
martysmartie's Avatar
martysmartie
I should think yours would just have a hose from the rocker cover to the carb.
Martin
Old Jan 4, 2011 | 06:40 PM
crock's Avatar
crock
i have a look 2 morrow,thanks 4 your help
DAZZER
Sep 30, 2015 08:43 PM
Sp3no
Sep 27, 2015 07:23 PM
