St170 brake conversion (Help!)
Old Jan 1, 2011 | 04:47 PM
chris1987's Avatar
chris1987
Default St170 brake conversion (Help!)
Rite i was racing a rs2000 escort down a carriageway and i was doing some stupid speed.
When i hit the brakes it stated moving to the left and then it would pull back to the rite but i was not skidding.
I herd a bang from the drivers wheel and lots of smoke came from that side then the left side went the same.
I totally lost control at this point but i never crashed.
I moved the car to a safe place on the carriageway got out and the disks was glowing a solid red and brake pads had gone and the calipers was hanging.
My mates said when i brought the car there not st front brakes there standard 1.6 Uprate them.
Of course i never listened i drove the car and this happened. So what do i need to uprate the front brakes. And is it a straight forward job
Old Jan 1, 2011 | 04:57 PM
phil_focus's Avatar
phil_focus
sounds to me like whoever last worked on the brakes did not do a very good job. are all the bolts still there? have any broken or fallen out?
to do the st170 conversion you will need st170 hubs/knuckles, st170 discs and either st170 callipers and pads OR any mondeo mk3 callipers and pads.
easy bolt off, bolt on job for anyone competant with a spanner.
Old Jan 1, 2011 | 05:16 PM
chris1987's Avatar
chris1987
No mate the bolts and pads have gone.The 1 disk is warped and its got a bigish hole in the disk All i have left is 1 hanging caliper other 1 has gone.
So no brakes on the front at all sounds easy enough what price do you think im looking at sure ive read some were its cheaper to do the rs conversion.
Old Jan 1, 2011 | 05:28 PM
phil_focus's Avatar
phil_focus
fuck me, one calliper has fallen off and the other is barely hanging on!! your lucky to be alive and whoever worked on the brakes last (i'm guessing previous owner) should be shot!
i got my callipers and hubs for Ł100 off ebay which was cheap at the time. don't know what they go for now but i wouldnt expect to pay more than Ł200 for used items. i'd be fitting new discs and pads at the same time. mine came with dics and pads that were advertised as worn but fine...they were fucked imho. also, sounds like one of your flexi hoses has ripped off (with one calliper doing a dissapearing act) and the other one will have been stressed so get a set of braided flexi hoses front and rear for it too. they will be upt Ł65 ish for a set. cheaper if you have rear drums.
Old Jan 1, 2011 | 05:50 PM
chris1987's Avatar
chris1987
The back brakes are st170 think they work fine all tho first m.o.t it went for it said they were recording little or no effect but i got that fixed. I 4rt the car was going to go over on the roof. Ive never been so shaken up i lived to tell the tail this time. I thought i was never going to see 2011 how fast i went side ways bobbling ready to go over on that carriageway. Its the drivers caliper that's gone both pads of each side have gone 1 disk is warped badly other worn down that much theirs a hole in it Other caliper is left hanging.
Old Jan 1, 2011 | 05:53 PM
dojj's Avatar
dojj
Resident Wrestling Legend
question the first, what car is it, year, model, etc
question the second, how big is the disc you currently have?
question the third, what size holes do you have in your hubs? (if the answer to question one is anything other than a mk1 focus)
Old Jan 1, 2011 | 05:54 PM
dojj's Avatar
dojj
also, there is a reason they use the correct bolts in brake kits and they put a blob of thread lock on them to keep them tight
Old Jan 1, 2011 | 05:58 PM
chris1987's Avatar
chris1987
focus mk 1 2001 1.6 (but its got the st170 engine in it)
Disks i guess now are standard 1.6 (and was not uprated like other owner said)
Old Jan 1, 2011 | 06:06 PM
phil_focus's Avatar
phil_focus
do your hubs look like this??
http://shop.mondeospares.co.uk/ekmps...2005-214-p.jpg
if so, then they are standard fit on mk1 1.4, 1.6, 1.8 and 2l.
also if the discs were that badly worn they were down to the fins when were they last checked? when was the last mot? i'd be very worried about the condition the rest of the car is in.
Old Jan 1, 2011 | 06:19 PM
chris1987's Avatar
chris1987
I had new disks about a month back and pads. Not sure what the hubs are like but they are standard 1.6 that are on it.
Old Jan 1, 2011 | 06:23 PM
Chaz888's Avatar
Chaz888
well done dude you have just won lifes lottery your alive !!!!!, got any pics of the brakes ?? ps have a good look over the rest of the car as sugested cos that is an epic fail !!!
Old Jan 1, 2011 | 06:27 PM
chris1987's Avatar
chris1987
Nah the cars down the recovery place were my dad works. I dont know how the car stayed on 4 wheels. So yeah i feel very lucky lol
Old Jan 1, 2011 | 09:34 PM
zippyobrien's Avatar
zippyobrien
I had a caliper come of on my rs1800 smashed the wheel to pieces , was on the motor way ay the time. Thought was going to die.
Old Jan 1, 2011 | 10:18 PM
Sp3no's Avatar
Sp3no
Please gets some pictures of the damage!! lucky to be alive, brakes should have been the first thing to be upgraded so a bit silly not doing this. Even the ST170 brakes are not much good at stopping from high speed, i managed to warp my disks after braking from high speed, i hate the wobble it gives
Old Jan 1, 2011 | 10:37 PM
focusrrx87's Avatar
focusrrx87
compbrake 330mm 6 pots
Old Jan 1, 2011 | 10:55 PM
phil_focus's Avatar
phil_focus
how much are they? from what i've read on here about compbrake are they actualy any good?
will still need st170 hubs to allow for different callipers and bigger discs.
Old Jan 1, 2011 | 11:01 PM
focusrrx87's Avatar
focusrrx87
never heard a bad review, cossie4i is using them iirc, very cheap compared to other kits. can be had on trade for under 1k
mine are on order now so will let ya know when the car is back from EP
Old Jan 1, 2011 | 11:07 PM
phil_focus's Avatar
phil_focus
ok cool.
i've just seen the odd negative comment about their stuff from time to time is all but i guess i may have missed the possitives.
will certainly be looking into them more when i turn my focus into a track car (eventually) as will be going forced induction so will be needing better than my curent st170 setup.
muzzman1
Sep 30, 2015 08:59 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
