RS Turbo Control Arms
Old Dec 29, 2010 | 03:20 PM
JamesyRS's Avatar
JamesyRS
Default RS Turbo Control Arms
Hey guys replaced these before but cant remember having to do this before but here goes. Removed but the metal dowel that is inside rubber of arm is stuck on anti roll bar, how do I remove this? bit of heat and try get it off? Obviously with it being on threaded area I dont want to bugger thread any help will be appreciated thanks.
Old Dec 29, 2010 | 04:19 PM
xrmalin's Avatar
xrmalin
Mine did this when i changed them to adjustable ones. I just bollocked a load of wd40 in there went for a fag whilst it was soaking in then got a big pair of mole grips on it and twisted it back and forth with abit more wd40 thrown in untill it was free.
Old Dec 29, 2010 | 04:30 PM
JamesyRS's Avatar
JamesyRS
thanks mate will try this tomorrow too cold now pml
Old Dec 29, 2010 | 08:34 PM
A very common problem, a few choices, if careful with a angle grinder grind a channel in the tube, not all the way through obviously, then insert a nicely sharpened cold chisel in the channel and whack, this will split the tube open, then mole grips to pull it off is the quickest way to do it.
skypeller
Sep 19, 2015 09:58 PM
Matt Baxter
Sep 16, 2015 08:30 PM
155lee
Aug 14, 2015 11:21 AM
Escortdriver1
Jul 31, 2015 02:36 PM
