V reg mk5 Fiesta heaters
Old Dec 21, 2010 | 03:33 PM
Default V reg mk5 Fiesta heaters
Hi there.
My wife has a mk5 1.25 16v fiesta and she is comlaining of the heaters been cold when she is driving to work.
She works about 25miles away and she says sometimes the heaters just to say get warm and other times its just really cold.
I put a heater cotrol valve on it a few weeks back but she says its still cold.It was a cheap aftermarket valve that i put on.Iv had a quick look tonight at it and felt the heat of the pipes going into and out of the valve.All 4 pipes are hot which makes me think the valve is working ok.The heaters were hot too.
Any help would be nice. Thanks....
Old Dec 21, 2010 | 03:35 PM
CarParts Express's Avatar
CarParts Express
try back flushing the matrix incase its got some crap in it affecting the flow
Old Dec 21, 2010 | 05:38 PM
martysmartie's Avatar
martysmartie
What he ^^ says, other possibility is a faulty thermostat, this is easy to tell by seeing what the reading on the temp gauge is.
Martin
Old Dec 21, 2010 | 06:16 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if it's the thermostat, on mine they had to remove the air con pump to get to it, so lots of work to change, but seeing as someone had bodged the old one on with some silicone, it had to be done
heating was nice afterwards
Old Dec 21, 2010 | 06:33 PM
phil_focus's Avatar
phil_focus
is the engine definately getting upto temp in these cold conditions?? when driving the cold air can be enough to cool the engine right down meaning the heaters don't get very hot.
Old Dec 21, 2010 | 06:38 PM
RichieST's Avatar
RichieST
Easiest way to fix it is to give her a slap glenn. That'll stop the moaning!
Old Dec 21, 2010 | 06:43 PM
Surely the pipes going to the heater valve would be cold if the thermostat wasnt working right.
I checked it again tonight after we just got in and the pipes in and out of the valve were hot but the heaters in the car were just to say warm.
Old Dec 21, 2010 | 06:44 PM
RichieST's Avatar
RichieST
Sludged up matrix I'd have thought!
Old Dec 21, 2010 | 06:45 PM
Easiest way to fix it is sell the old dog lol.
Old Dec 21, 2010 | 06:47 PM
RichieST's Avatar
RichieST
The car or the wife?
Old Dec 21, 2010 | 06:50 PM
Where abouts is the thermostat at then on these fiestas.I thought it was on the side of the engine.
Old Dec 21, 2010 | 06:57 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
The thermostat should ensure this is happening. Only reason it'll not get very hot is if the thermo was stuck wide open, but, it'd still get warm. If it's stuck closed, there is no way that air passing over the engine would cool it down. It'd still overheat.
Old Dec 21, 2010 | 07:04 PM
dojj's Avatar
dojj
it's in the front, under the inlet manifold mate
Old Dec 21, 2010 | 07:20 PM
cabriolet's Avatar
cabriolet
backflush heater matrix .unless the temperature rises in traffic if it does then change thermostat
Old Dec 21, 2010 | 07:25 PM
Never, i will have a look tomorrow and see where it is.
Old Dec 21, 2010 | 07:26 PM
Its fine in traffic.I will try and flush the heater matrix tomorrow.
Old Dec 21, 2010 | 07:27 PM
Im pretty sure if the car is stood still and the engine is reved it gets warm.
Old Dec 21, 2010 | 08:22 PM
martysmartie
Flush the matrix as it's easy to do and free and it's worthwhile doing anyway, if no luck then I would be looking at the stat, if ever in any doubt as to location just trace the top hose back.
Martin
Old Dec 21, 2010 | 09:43 PM
phil_focus's Avatar
phil_focus
true but i was thinking that maybe the water is getting hot enough to open the stat but in the cold weather not able to get upto full running temp, especially when moving. i've noticed mine gets upto temp idling on the drive but when moving the temp guage shows it running a little cooler but not enough to close the stat. it may only be 10 degrees or so but could easily be enough to stop the heaters getting upto full temp.
Old Dec 21, 2010 | 09:59 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
I'd expect it'd be a faulty stat if it's bad enough to notice through heaters. I check my temp whilst driving in this weather (on scangauge) and it still happily stays around where it does normally, even when driving at very low revs. Also was doing 70+ on the m25 (also through the 50 zone, in 5th, with fuck all revs), with an intake temp of -6oC(was half 12 friday night), and the car stayed up to temperature. mines got the same engine variant, the se. Albeit in a bigger displacement.
Old Dec 21, 2010 | 10:16 PM
phil_focus's Avatar
phil_focus
hmm, i think my focus can display the actual temp on the dash so might give that ago...now thinking my stat might be on its way out haha.
Old Dec 22, 2010 | 05:19 AM
If the thermostat was faulty or not working correctly surely the pipes going to the matrix would be cold?
Old Dec 22, 2010 | 07:36 AM
The wife has just told me the heaters were warm today on her way to work.It has been really cold these past few days but this morning it wasnt really cold.
I think the cardboard trick in front of the radiator will have to be put into action ha ha lol.
Old Dec 22, 2010 | 08:44 AM
martysmartie
It does not matter what the ambient temperature is, this is the very reason for a stat I.E to regulate the temperature, so say if you have an 86 degree stat it will not open until the coolant is at this temp at which point it can get back to the rad, anything below this temperature the stat closes or slows the flow meaning coolant can not get back to the rad and so will not get cooled.
However if the stat is stuck open the coolant will get over cooled so effectively it's the same as running with no thermostat, so the engine will warm up very slowly and the coolant will not get to the correct temp hence being mirrored in the heating.
This is why the heating gets warm but never hot and when you start moving it goes cold again as the coolant is being over cooled.
Yes Focus will display the temp from CHT on the digital dash amongst a whole variety of other useful info.
Martin
Old Dec 22, 2010 | 11:15 AM
Top info there mate. Would the pipes at the heater valve not be cold though.
Old Dec 22, 2010 | 11:30 AM
phil_focus's Avatar
phil_focus
i think the difference we are only going to see at the heaters between the engine only reaching 86 degrees and being able to reach 100 degrees is a warm cabin or a stinking hot cabin. without seeing the car in question its hard to say whats happening to be honest but i think its more along the lines of not being able to get stinking hot like she's been used in warmer weather.
Old Dec 22, 2010 | 01:00 PM
martysmartie
The pipes won't be cold but they may not be as hot as what they otherwise normally would be. I.E you feeling them may just be warm, if faulty stat this will cool down with the car in motion I would defo err on the stat, other possibility would be clogged matrix but it's unlikely unless the cooling system has been neglected.
Way to test the stat is on a cold start by feeling the top rad hose, if you can feel coolant running through it then the stat is not doing it's job.
Martin
Old Dec 22, 2010 | 01:40 PM
I dont think the matrix is blocked cause surely the heaters wudnt be going hot and cold all the time. Im now thinking it could be the stat. I just hope its not a coont to change.
Old Dec 22, 2010 | 01:47 PM
martysmartie
I personally think it's the stat, I originally suspected matrix or stat as in my original reply but know I know more info. A blocked matrix can give warm bursts sometimes. Do you know what the temp gauge reading is as this will be a good indication?
Martin
Old Dec 22, 2010 | 01:48 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Just incase...she does know how to use the heater control panel, yes?
Old Dec 22, 2010 | 03:35 PM
Is it definatey there Dojj. Ive just had a look at the car now and it looks like a right twat to get at. It looks like its under the alternator with 2 pipes coming off it. The big radiator pipe coming from the thermostat was a bit cold then when the car was sat running the pipe get warm.
Old Dec 22, 2010 | 03:39 PM
Are you taking the piss lol.
Old Dec 23, 2010 | 09:38 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Kinda, but she is a woman, and you can't always be sure with them.
Old Dec 23, 2010 | 09:57 PM
dojj's Avatar
dojj
is it sorted then?
or are you going to get busy with the spanners on saturday morning
bobsworth
77
Mar 24, 2016 09:30 PM
gcfcos
59
Oct 6, 2015 05:04 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Steve Escos
Oct 1, 2015 06:57 AM
