Is Amal valve needed ?
Old Dec 12, 2010 | 06:57 PM
Hoogi's Avatar
Hoogi
Default Is Amal valve needed ?
If you use a Mechanical Boost Controller (ie Turbosmart Unit) do you need to run an Amal Valve ?????
So many questions.........
Old Dec 13, 2010 | 12:31 PM
martysmartie's Avatar
martysmartie
No one or the other, the Amal is far superior to the aftermarket mechanical bleed valves and the ECU has control over boost as well!
Martin
shortie
Aug 19, 2015 01:01 AM
Churtz
15
Aug 13, 2015 06:40 PM
muffster
Aug 11, 2015 05:39 PM
col93saphcos
Aug 7, 2015 03:21 PM
jdsjojo
Aug 1, 2015 08:50 PM
