mondeo tdci 130 help please
Old Dec 12, 2010 | 05:03 PM
ogie1xr3i's Avatar
ogie1xr3i
Default mondeo tdci 130 help please
glow plug light flashes,engine starts after a while with loads of white smoke,dash board doesnt work,no aircon,radio,electric windows.this all happened at once .trip button held for test and no fault codes show up. in limp home mode please help as were desperate.
Old Dec 12, 2010 | 06:06 PM
forevaford's Avatar
forevaford
code reader for any fault codes on engine ecu
Old Dec 12, 2010 | 06:19 PM
ogie1xr3i's Avatar
ogie1xr3i
rac gave us a fault code of p2339
Old Dec 12, 2010 | 06:26 PM
ogie1xr3i's Avatar
ogie1xr3i
we had it checked by rac and they thort it was injectors
Old Dec 12, 2010 | 08:03 PM
forevaford's Avatar
forevaford
the common for P2339 is injector fault causing a cylinder knock problem, have somone recode the injectors, and should be fine for a while again. at worst new injectors needed
Old Dec 12, 2010 | 08:32 PM
ogie1xr3i's Avatar
ogie1xr3i
wot about elctric windows not working and air con ,radio and rev counter it says its 37 degrees outside i wish
Old Dec 14, 2010 | 11:16 AM
forevaford's Avatar
forevaford
ha ha, im not sure, this seems a seperate fault to that of the engine management. try checking fuses or relays. have you got the original hand book to the mondeo? this wil help locate fuses etc.
oh just 1 more thing i had on a focus tdci, under the passenger footwell theirs the fuse box with wire multiplugs, a pasenger caught his foon on a wire and unplugged it slightly, this took heater blower, windows, mirrors etc.
its worth having a general look around for any obvious wireing/electrical faults.
good look
mart
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
