oil cooler on mondeo zetec going into mk2 xr2
Turbocharging Technician
no its not, its got a remote oil filter, with a custom housing on the original mondeo pump, the filter is mounted on a custom bracket on the block, you need to know if the mondeo pump clears the driveshaft if fitted with a normal filter.
Adam Graham
06-09-2015 06:04 AM
