Newbie Focus ST170 advice
Old Dec 5, 2010 | 01:28 PM
big al 1977's Avatar
big al 1977
Default Newbie Focus ST170 advice
Hi
I've just got an 03 focus ST170. Really pleased with it. Only slight niggle is smell of petrol/fumes when sat in traffic. The exhaust sounds like it's blowing a little bit - could this be the cause, or should I be more concerned? Please bear in mind I have extremely limited mechanical knowledge before you respond!
Al
Old Dec 5, 2010 | 07:00 PM
Why not fix the blowing exhaust anyway, then see if you still have the same problem.
I would also just have a look underneath the bonnet, and at the fuel lines etc to make sure there is no leak of fuel.
Old Dec 5, 2010 | 07:16 PM
RS Juto's Avatar
RS Juto
Its more than likely to be the flexible joint and this will cause the smell.
Old Dec 6, 2010 | 09:30 AM
Sp3no's Avatar
Sp3no
Get under the car once it is safely supported on axle stands, turn the engine on and get a mate to stick a rag in the end of the exhaust for a couple of seconds at a time, this will make any leaks in the exhaust more obvious, look for soot around joints also which is an indicator of a leak.
Old Dec 8, 2010 | 04:50 PM
big al 1977
Problem solved - bloody mechanic had left the oil filler cap off! Tw@t. Fortunately spotted it before I went for my first good, hard thraping!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
Sep 3, 2015 10:49 AM
kevin36
Sep 2, 2015 06:24 PM
