siemens
Old Nov 26, 2010 | 04:36 PM
matcossy's Avatar
matcossy
Default siemens
can any one tell me wich is best l1 ecu and greys or l6 with 55's??
Old Nov 26, 2010 | 05:55 PM
Turbosimpsons's Avatar
Turbosimpsons
l6 with 55's
Old Nov 26, 2010 | 05:58 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
or l8 with either......daft question really, ask ur tuner
Old Nov 27, 2010 | 01:30 PM
greys with a different aftermarket ecu.
Old Nov 28, 2010 | 10:06 AM
martysmartie's Avatar
martysmartie
L1 and L6 arn't really alot different just different electronics really so no benefit, L8 you will only benefit from if you want things like ALS, LC.
Any ECU can be mapped for the injectors, some tuners can not map greys properly and so find someone who can, if buying new the Siemens makes sense.
Martin
Old Nov 28, 2010 | 10:36 AM
If the tuner you use for mapping can't map greys, run away as fast as you can, and go elsewhere!!
Nov 1, 2015 06:53 PM
Danielbetty
Oct 3, 2015 06:01 PM
timsrs
22
Sep 24, 2015 08:14 PM
cos elle
Sep 16, 2015 06:37 PM
Alan s1
Mar 29, 2007 05:34 PM
