mk6 escort td waterpump
Old Nov 19, 2010 | 06:24 PM
xr2imetalhead's Avatar
xr2imetalhead
Default mk6 escort td waterpump
hi guys i just bought a 95 td escort and on the way home the water pump bearings have gone and its leaking coolant can anyone give me some information on changing the pump and cam belt eg how hard it is or maybe a guide cant find one anywhere.
any help would be apreciated
cheers
lee
Old Nov 21, 2010 | 09:48 PM
jamie's's Avatar
jamie's
its easy enough to change if your competant and have the timing tools,
theres 2 timing belts on these engines, be advisable to change them bothwhile they're off,
they were bad for the idlers breaking up as well so full timing belt kit is your best bet,
as the water pump runs off the cam belt they need to come off anyhow,
if your competant enough you shaould be able to do it on a sat afternoon no probs
Old Nov 22, 2010 | 12:40 PM
Excellent advice, esp about doing both belts, the shorter one ie pump belt is often neglected, snaps and gets tangled up in the cam belt wrecking things.
You can do the timing with drill bits as well, as only pins, think they're 8mm but not done one a long time so don't quote me on that.
Old Nov 22, 2010 | 01:58 PM
gouch1's Avatar
gouch1
make sure you use a good belt kit like a gates powergrip not realy worth using cheap ones
Old Nov 22, 2010 | 02:36 PM
I use the DAYCO kits, even on me cossie, never had a problem.
rex647
Mar 6, 2022 06:20 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
