Please help.
Old Oct 27, 2010 | 12:15 PM
Lapetitefleurx's Avatar
Lapetitefleurx
Default Please help.
Hey, basically I have a 2000 made ford fiesta (uncle festa) and his main beams aren't working. All of the fuses are working an I'm stuck. Can you help?
Old Oct 27, 2010 | 05:30 PM
a_morti's Avatar
a_morti
Find the relay and test that by swapping out with the other headlight relay. If the relay is OK:
Bridge the two fat wires into the relay plug, see if the high beams come on. That proves it's not the actual headlight connectors or the bulbs.
Switch high beams on, check if that makes 12v come into the switched live. Checks the switch and the live feed.
Check if the switched ground gets through to earth. Self-explanatory
Old Oct 28, 2010 | 08:24 AM
Good explanation there ^^^.
muzzman1
Sep 30, 2015 08:59 PM
TC-ST3
Sep 26, 2015 04:47 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
