2001 old shape focus starting issues
Old Oct 27, 2010 | 09:14 AM
uniquemotors's Avatar
uniquemotors
Default 2001 old shape focus starting issues
morning all.
i have just joined this site and hope someone can help me solve the problem i have with my focus....the fault is as follows.......
when the vehicle is cold (first thing in the morning) it will fire up and idle for about 30 seconds and then cut out....but will restart straight away.... if you rev the engine whislt stationary it revs cleanly and you can hold the revs and they seem fine..
after a few minutes the revs become very lumpy at idle and when you try and rev the engine you get no response and have to play with the throttle and then it appears to clear and will rev..
i have carried out a diag and the only code indicated mass air flow sensor...this has been replaced but its no better..
i have also replaced the plugs and cylinder head temp sensor....i have also replaced the pre cat lambda and even dissconnected the cat to ensure exhaust wasnt blocked...i have also checked the cambelt timing and this is spot on.........
CAN ANYONE HELP ME!!!!!!!!!!!!!!!!!!!!
regards
marcus
Old Oct 28, 2010 | 08:29 AM
When was the fuel filter last changed ?
Old Oct 28, 2010 | 04:44 PM
uniquemotors
hi there....
filter was changed 18 months ago but just fitted a new one and its made no difference?????????????
JoeyBoyden
Jan 4, 2024 02:36 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Bailes1992
Aug 16, 2015 07:14 PM
druidgetafix
Aug 15, 2015 10:22 AM
