mondao
Old Oct 24, 2010 | 01:59 PM
mas's Avatar
mas
Default mondao
iv just changed clutch in my 2003 tdci
put it all back together and i will not start
any sugestions
Old Oct 24, 2010 | 02:04 PM
danzul's Avatar
danzul
i take it all the earth wires under the battery tray are connected back up?
i did a clutch on one of these a few weeks ago but cant think of much....
did you replace the DMF? i noticed the one i did had lateral play in it which could effect the starter motor by not angaging with it properly.
Old Oct 24, 2010 | 02:12 PM
mas's Avatar
mas
i got the complete kit with flywheel, clutch presure plate, slave
Old Oct 24, 2010 | 02:15 PM
phil_focus's Avatar
phil_focus
bit vague that, whats happening when you turn the key???
does the engine turn over???
i'd guess you've missed connecting something up.
Old Oct 24, 2010 | 02:17 PM
p285e's Avatar
p285e
Did you check your old DMF and the new one before to place it ?
Check the crank sensor, it take the information to start the engine on the DMF
Old Oct 24, 2010 | 02:39 PM
mas's Avatar
mas
engien turns over all fine add crank sens out it looks ok
the 2 flywheels looked the same
all wiers and leads on
thing im thinking is the locating pin on end of crank
because the flywheel i got only had one pin hole ( even tho the old flywheel only used the one pin but had tow holes )
could the flywheel be 180 deg out.
Old Oct 24, 2010 | 02:43 PM
phil_focus's Avatar
phil_focus
fly should only be able to go on one way as the bolt holes are misaligned, is the pin on the new fly in the same place as the old fly?
Old Oct 24, 2010 | 02:45 PM
botters's Avatar
botters
competant bodger
its possible i know people who have done this before not on a mondeo tho
Old Oct 24, 2010 | 02:48 PM
mas's Avatar
mas
the pin was still in crank
all holes lined up
easy fit
Old Oct 24, 2010 | 02:57 PM
phil_focus's Avatar
phil_focus
hmmm, if you've fitted the new clutch and fly properly and any timing pins etc line up then i can only think theres a sensor not connected somewhere.
jonholdcroft86
Ford Focus Diesel
Mar 26, 2015 07:38 PM
xr2boy
Wheels and Tyres
Aug 13, 2013 11:16 AM
tones
Aug 6, 2011 11:39 PM
Tev
Insurance
Sep 22, 2010 08:12 PM
crummyboy
Jan 1, 2010 11:15 PM
