brake pedal problem
Old Mar 25, 2004 | 06:36 PM
The Youth.'s Avatar
The Youth.
Default brake pedal problem
since buying my 93 orion runabout the brake pedal has to be pushed halfway down before it actually applies the brakes, there is nothing wrong with the pads/disks so I can only think it is the master cylinder at fault, is there any way I can prove this or has anyone come accross this problem before?
cheers,
steve
Old Mar 25, 2004 | 09:13 PM
dickie's Avatar
dickie
i take it you've tried bleedin the brakes???
pop the vacuum pipe off the servo and look inside the servo,
is there any brake fluid inside??
Old Mar 25, 2004 | 09:17 PM
Fast Guy's Avatar
Fast Guy
I had a master cylinder go on a previous car and over the course of a week the pedal went from normal, to lower and lower until it hit the floor.
Old Mar 26, 2004 | 07:51 AM
The Youth.'s Avatar
The Youth.
cheers for the replies guys, I will check the servo out and if it's ok then I will get a new master cylinder.
steve
Old Mar 27, 2004 | 10:53 PM
dave cos4x4's Avatar
dave cos4x4
Steve, i had a astra and this sounds similar.
I changed the fluid in the car,must have been really old and the brake pedal felt spot on then.
Could be that.
Dave.
yatta
May 21, 2016 10:31 PM
focus2351
Sep 9, 2015 09:33 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
