Manual Choke conversion
Old Oct 22, 2010 | 04:42 PM
chris m1's Avatar
chris m1
Default Manual Choke conversion
Right 3 questions in 1 so here goes
Just picked up a refurbished weber DFT which has been converted to run on water choke..question is how do i convert it or is it nessacery to convert it to run on manual choke or is it true that i can be run without?.. Its repalcing the VW carb on a 1400cvh
Old Oct 22, 2010 | 05:19 PM
chris m1's Avatar
chris m1
Anyone any ideas?..looking to fit tommrrow
Old Oct 23, 2010 | 07:27 PM
Just use the water heated choke if you have the pipes ?, they can be converted to manual choke, but a correctly set auto choke is perfect in operation.
Old Oct 23, 2010 | 08:00 PM
chris m1's Avatar
chris m1
the carb has all just been rebuilt so to take it to picecs to me does seem pointless.. i pressume then its a case of finding the hoses to divert flow from the heater side of the plumbing
Old Oct 24, 2010 | 08:35 AM
Yes needs to be on the "heater" side of the coolant system, don't know the pipework on your car.
Old Oct 24, 2010 | 11:35 AM
chris m1's Avatar
chris m1
Cheers Tabs, ill hae a trawl of the usual places and see what turns up
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
