twin coil or single coil?
Old Oct 20, 2010 | 10:31 PM
omightone's Avatar
omightone
Default twin coil or single coil?
Hi guys, looking at getting a Omex Clubman rev limiter for my 1996 1.8 zetec escort. but they come in single coil or twin coil and i dont know which one i need for my car? & does anyone know where it exactly connects up to? the ignition coil or the coil pack?
cheers.
Old Oct 21, 2010 | 07:45 AM
As you have a zetec you need twin coil, single coil means the conventional(old) set up with a distributor and a cylindrical type coil, whereas your zetec uses a coil pack which is effectively 2 coils in one, using wasted spark.
The rev limiter connects into the three pin plug connection, usually earthing out the negative wires momentarily which pulse each side of the coil, for cylinders 1+4 and 2+3 to effect no spark, no over rev.
Old Oct 21, 2010 | 07:01 PM
omightone's Avatar
omightone
thank you very much
Old Oct 21, 2010 | 07:11 PM
phil_focus's Avatar
phil_focus
i thought the mk6 zetec engined escorts had a rev limmiter from the factory. i'm sure my 1.6 had one around the 6,800 rpm mark??!!
Old Oct 21, 2010 | 07:59 PM
I assume he has a different ecu ?, but yes as std has rev limiter.
Old Oct 21, 2010 | 08:10 PM
phil_focus's Avatar
phil_focus
few, thought i was going mad then
Old Oct 21, 2010 | 08:12 PM
omightone's Avatar
omightone
Yeah, they do. but the way im doing it is having a omex rev limiter with launch control and fast road cams ect. bit of a track car
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
