Mk 3 Mondeo window help . . .
Old Oct 17, 2010 | 12:32 PM
Series1Dry's Avatar
Series1Dry
Default Mk 3 Mondeo window help . . .
Front electric driver's window motor has stopped working. Motor not at fault cos it works on passenger side. 4 gang switch has been swapped for a new one and it's still the same. I presume it's a relay problem but not sure. Any suggestions ? cheeRS
Old Oct 17, 2010 | 04:44 PM
You need to start probing for live output from the switch and work towards the window, you'll find it, might be worth trying a new timer module from scrappies on the dud window.
Old Oct 17, 2010 | 05:28 PM
RichieST's Avatar
RichieST
When you press the switch, can you hear like a tick tock noise, as the motor engages then instantly disengages? If so, the spring on the auto down bit has failed and due to resistance with the window in the rubbers, it is instantly cutting the power to the window as it thinks it's at the bottom. Quite a common fault on the focus.
Old Nov 15, 2010 | 06:57 PM
Series1Dry's Avatar
Series1Dry
I've swapped the motors over and the passenger side works fine.
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
cossie330
Sep 27, 2015 04:13 PM
