Rs1600i cam timing
Old Oct 10, 2010 | 08:38 AM
jhot80's Avatar
jhot80
Default Rs1600i cam timing
Does anybody know what the cam timing is for an rs1600i cam. Im itching to change the cam over but dont know what the timing only know that its different from a standard cvh cam.
James
Old Oct 10, 2010 | 08:46 AM
Does the 1600i use a vernier ?, I can't see that it would, in which case the cam/s will all be dialled in to the std key setting.
Old Oct 10, 2010 | 08:58 AM
jhot80's Avatar
jhot80
Im pretty sure it doesnt. So the cam are just in different postion the the key? That makes things alot easier. No need to get out the timing stuff.
Old Oct 10, 2010 | 05:13 PM
The cams are keyed to fit the std pulleys, whether 1600i or rst etc.
RUBY123
Oct 22, 2023 12:04 PM
Danielbetty
Oct 3, 2015 06:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
