Wiper linkage
Old Oct 4, 2010 | 09:43 AM
Mich's Avatar
Mich
Default Wiper linkage
I've just had one of the arms fall off which is extremely helpful in this weather, is there anyway to fix it or does it mean I need to replace the entire linkage ??
Old Oct 4, 2010 | 06:21 PM
Car would help ?, a Fiat by any chance done them before now!!
Old Oct 4, 2010 | 07:23 PM
Mich's Avatar
Mich
Sorry its an 88 Sapphire Cosworth, Ford no longer sell the linkages, Is it possible to get hold of the nylon bush that its obviously worn out, or has no one else had this happen yet? Currently a cable tie is holding it in place but that's not a real solution to the problem at all really.
CheeRS
Old Oct 5, 2010 | 08:32 AM
I've only ever known one to have a problem, was a sunday eve so I fixed it with a rose joint welded to the link arm, with a bolt and washers after welding a bolt in place of the stub.
I'm a bit better these days but would fix in a similar manner if having trouble getting the parts.
Loads of sierra parts on the bay though, my own cossie has done 200,000 miles and no discernable wear that I've noticed so they do last normally.
I'd just raid the scrappies first there's bound to be the same bush on loads of fords, if not, as a last resort one can be made from delrin on a lathe no probs, let me know.
Old Oct 5, 2010 | 08:46 AM
Mich's Avatar
Mich
Ok thanks for that I'll let you know how I get on
CheeRS
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
borboyous
Aug 22, 2015 11:17 AM
Matt Baxter
Aug 10, 2015 09:42 PM
Old ford
Jul 31, 2015 06:50 AM
