chipped or not????
Old Jan 24, 2005 | 09:49 AM
martinmace's Avatar
martinmace
Default chipped or not????
can anyone tell me if this has been chipped or not, and also where is map sensor located as i need to know what to buy and what not to buy. number on chip if this is the right 1 is...TMS 27C128-2JL LDE 8805
Old Jan 24, 2005 | 01:20 PM
rsjohn's Avatar
rsjohn
Do you know what boost your car is running???
john
Old Jan 24, 2005 | 02:48 PM
martinmace's Avatar
martinmace
yep!! i have got the boost turned down at the mo and she is running 0.6 bar , when turned up she will run 1.5 bar but i havent done that very often as i am still unsure what the car has had done as i have only had this 1 just over a week. it may run more boost but i have not really given it a good thrashing until i have had it set up on the rollers...the bloke i had the car off only had it a month and he new fuck all about cars so i want to find out what its got before i start throwing wads of cash at it if you know what i mean
Old Jan 24, 2005 | 06:06 PM
Alvyn's Avatar
Alvyn
what colour injectors has your car got on it ie dark blues(standard stage1) ,light greens stage 2,dark greens stage3 and so on
the map sensor is or should be just under the header tank held in place by 3x 10m bolts!
Old Jan 24, 2005 | 06:32 PM
martinmace's Avatar
martinmace
it is only running standard injectors at the moment, going to put some greens in this is why im trying to establish if it has a 3 bar on and if it is allready chipped or not mate
Old Jan 24, 2005 | 07:11 PM
Alvyn's Avatar
Alvyn
DONT think it will have a 3bar on standard injectors!
ps 3bars are usually a greyish sort of colour with numbers APSO5/01 I think BUT although there were a few black ones if thats helps!
Old Jan 24, 2005 | 08:17 PM
Stu @ M Developments's Avatar
PassionFords Creator
100% impossible to tell if its chipped from that pic. get it read by a pro before it ends in tears is my advice on this occasion
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
RSmark84
Sep 13, 2015 01:29 PM
