mk1 focus central locking problem
Old Sep 6, 2010 | 11:31 AM
indianlarry's Avatar
indianlarry
Default mk1 focus central locking problem
been looking on forum about central locking problems on mk1 focus, but none seem to have my problem, if you try and lock doors using key fob remote it seem to bounce back open eg tries to lock but instantly unlocks, but if you lock/unlock the old fashioned way by putting key in drivers door lock central locking works fine, does anyone have any ideas as to problem?
Old Sep 6, 2010 | 05:57 PM
Classic problem, one of the mater locks, ie either front door has a sticky/sluggish motor mechanism, so one lock opens fully one doesn't open fully, nearly but not quite, when the pulse for open stops it leaves one lock saying it should be locked, so they relock, easiest way to find which is disconnect each door lock electrical supply at a time and see which one immediately relocks upon pressing unlock.
You will most likely be able to free off the mechanism, could be part of the linkage, the grease they use can attract dust dirt grit etc causing the sticky action, rarely a lock fault itself, almost always the linkages etc.
Old Sep 6, 2010 | 06:11 PM
indianlarry
thank you, will get door panels off this weekend!!
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
tankybaby66
Aug 9, 2015 07:13 AM
