Corsa column....B or C??
Old Aug 20, 2010 | 10:17 PM
kaisersolsay's Avatar
kaisersolsay
Default Corsa column....B or C??
Hi,
I have fitted a Corsa column to my Mk1 Cortina but dont know if its a B or C. I have measured the splined column where the boss slips on and its 20mm. Any ideas guys?
Old Aug 21, 2010 | 09:03 AM
my-first-rst's Avatar
my-first-rst
tokey smurbo
put a pic up i should be able to tell ya by looking at it
Old Aug 21, 2010 | 09:07 AM
graham c's Avatar
graham c
if its that one you got off me its a c matey the b,s are the same spline as the mk1 escorts about 15mm. the c,s are 20mm
Old Aug 21, 2010 | 08:40 PM
kaisersolsay
Cheers Graham! I thought I had asked you before but you weren't sure!
Front suspension stripped today for powder-coating.
How you getting on with the motor matey?
Old Aug 22, 2010 | 03:32 PM
graham c's Avatar
graham c
its good its getting blacks soon t34, gas! is on so should be mental
Old Aug 22, 2010 | 05:11 PM
kaisersolsay
I've got a T34 for mine..what housing you using? 48 or 63? I have the 63 on but may change down if too laggy.
Old Aug 22, 2010 | 05:17 PM
graham c's Avatar
graham c
going 63 sod the lag, power !
Old Aug 22, 2010 | 05:24 PM
kaisersolsay
I was thinking that the car weighs considerably less than a Saph so should accelerate through the rev range far quicker anyway. What rear diff you using?
Old Aug 24, 2010 | 04:34 PM
graham c's Avatar
graham c
standerd for now
Old Aug 24, 2010 | 08:55 PM
kaisersolsay
Do you have any issue with a standard diff?
Old Aug 25, 2010 | 04:22 PM
graham c's Avatar
graham c
not yet but my t34 and blacks will be on next week, so we,ll see then
IainRS1700T
Sep 25, 2015 06:44 AM
Dan@Rapid-Ford
Nov 2, 2005 10:38 AM
