OFAB temp sensors question...
Old Jul 30, 2010 | 09:43 AM
cabbykarl's Avatar
cabbykarl
Default OFAB temp sensors question...
Hi there, i've been running my zetec turbo on OFAB management for nearly a couple of years now but have always thought it slows down considerably when warmed up. Obviously I don't want to thrash it when cold but until it's reached normal temp it's super responsive throughout the rev range. When warm even before any boost you can feel there's just not as much torque.
It's been built with a rover inlet but i've never inspected it's sensors. I do have a spare fiesta rs turbo working EFI head with inlet inc temp sensors so might swap them to see if there's a difference.
However, does the zetec engine in general run hotter than the CVH as normal so would the OFAB be retarding the ignition thinking the engine temp's too high?
Temp only runs halfway up the guage, so seems ok...
Any suggestions would be welcome,
Thanks,
Karl.
Old Jul 30, 2010 | 09:51 AM
oldford's Avatar
oldford
Engine temperature sensor for the management is a different sensor than for your dash.
So, dash temp gauge doesn't mean anything here.
Change the inlet air temperature sensor for an original one.
Or measure the air fuel ratio on a rolling road.
Old Jul 30, 2010 | 06:18 PM
cabbykarl's Avatar
cabbykarl
Yeah, i'll follow your suggestions.
Thanks for the reply
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
