3 Door Help
Old Jul 27, 2010 | 01:34 PM
wilmot's Avatar
wilmot
Default 3 Door Help
Some of you may know I have a 3 Door Cossy converted to 4x4 about 24 years ago... all these years Ive not had a rear anti roll bar as neither the 3 door one or the 4x4 one fits.......... Does anyone have any thoughts or info how I can get round this problem, Photos would be even better.. Their has to be a way round this, im also VERY well aware we have a lot of very clever people who read this Forum.... Any advice to this rather unique problem... Thanks to all who help with this.... Noel.. (Liege-Belgium)
Last edited by wilmot; Jul 27, 2010 at 01:35 PM. Reason: Should have read it first
Old Jul 27, 2010 | 01:54 PM
boy-racer-1's Avatar
boy-racer-1
im prety sure a mk1 sierra 4x4 rear axle has an anti roll bar why not swap to that?
Old Jul 27, 2010 | 05:05 PM
jon@work's Avatar
jon@work
Without changing the beam, change the trailing arms to some that have got the ARB mounts on, then use a mark 1 sierra cossie ARB
Old Jul 29, 2010 | 07:57 AM
You can certainly do as jon@work says, but having had a xr4i myself I would advise you to do a little welding and make attachements for the sapphire type rear arb, the 3 door cossie one, like I used is not worth the effort of fitting imo, though better than the 4i one, it's still pretty useless being too thin and long, sapphire 16mm(2wd),18mm(4wd), or escos 22mm improve it no end, though if you have been able to put up with a lack of rear arb for that length of time anything would seem ace even the std 4i one!!
I also had a tow bar on my 4i with the 18mm rear arb from a sapphy so there is room, I merely welded two plates on the flat "chassis" type bit above/behind the diff to locate the arb mounts.
Old Aug 3, 2010 | 09:25 AM
wilmot's Avatar
wilmot
Great news lads, thanks to all for the Info... Got a 4x4 ARB from Flea Bay, just need to find someone I can TRUST to weld some mounts on for me...
Old Aug 3, 2010 | 09:32 AM
joffy's Avatar
joffy
SLOW LEARNER
Depends where you are but adrenaline in northampton would be my vote
Old Aug 3, 2010 | 09:33 AM
joffy's Avatar
joffy
SLOW LEARNER
Scrap that, your in belgium lol
Old Aug 3, 2010 | 11:08 AM
wilmot's Avatar
wilmot
Would come back with my car if everything was arranged up front and no hanging about ... Cash waiting for a TOP CLASS job.. anyone interested.. ???
Old Aug 3, 2010 | 01:57 PM
Just go to any half decent garage that does welding, it's avery easy job.
There is a garage/unit on Hillegom Strasse, in Amsterdam, but a bit far too, Betina Pilz owns the unit, they do a lot of rally prep so well up to this.
chowfornow
14
Jan 5, 2019 09:01 PM
mpilk
Sep 27, 2015 09:21 AM
Vacuman
Sep 22, 2015 12:09 PM
Vincereese
Sep 18, 2015 12:48 PM
