running lean
Old Jul 24, 2010 | 11:55 AM
foreverford255's Avatar
foreverford255
Default running lean
hi ppl
ive converted my efi cabby to efi turbo using ofac management but when i took it for a setup it was running massivley lean 0.20 %
the tuner reckons things are working as should but discovered an ecu fault,
so ive changed the ecu and it did make a differance to the drive of the car if a bit sluggish but when he checked it again it is still very lean.
so he checked the flow of the fuel pump and said it wasnt flowing enough so ive just fitted an uprated one from msd and its still the same.
its just sitting around 0.20%
so, any ideas what would cause it to run lean constantly
cheers
mick
Old Jul 24, 2010 | 12:12 PM
oldford's Avatar
oldford
Low fuel pressure (regulator?), intake air temperature very high, air leaks?
Are you using a map-sensor or an air mass sensor?
Do you have an Oxygen sensor connected and if so, what's the signal?
Old Jul 24, 2010 | 12:17 PM
foreverford255
im not using a oxy sensor and im using a map sensor
i sorted air leaks out yesterday as we used a smoke machine thing lol
the fuel pressure was also tested to so im a bit stumped
cheers
mick
Old Jul 24, 2010 | 12:31 PM
oldford's Avatar
oldford
Intake air temperature? What do you read in your setup program?
Old Jul 24, 2010 | 12:34 PM
foreverford255
i dont know what its reading as i dont have the equipment at home
cheers
Old Jul 25, 2010 | 09:15 AM
foreverford255
someone must have an idea
Old Jul 25, 2010 | 11:06 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you say it's lean but what do you think that means exactly?
what are the egt's like and is it detting?
if the above are fine then there is no problem, you want it leaner on cruise to save fuel.
as for on boost, well you want to head for whatever is safe and makes best power, this is different on all cars.
what wideband was used?
what injectors are being used and have they been cleaned?
what were the AFR figures?
mine runs 15.0 on idle is pretty smooth and produce piss all emissions, just seems to burn really well, not so great on economy up the revs though
Old Jul 26, 2010 | 08:17 PM
foreverford255
he hasnt had it on the rollers as he says its too lean and im pretty new to turbos so im just going of what he has said,but it feels pretty gutless on the road and gets hot quick which says to me not enough fuel.
its going back in wednesday for further investigation so ill see what happens
cheers
Old Jul 28, 2010 | 08:17 PM
foreverford255
well looks like my map sensor is knackered so on the hunt for a ofac map sensor now
bloody car uuurrrgghhhh
cheers
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
