Strange indicator problem with trailer
Old Jul 23, 2010 | 07:56 PM
davey_b's Avatar
davey_b
Default Strange indicator problem with trailer
I just fitted a towbar to my 2008 1.8 TDCi Focus and I had a bit of a problem getting the electrics sorted but me and a mate spent a bit of time yesterday night on it and all seemed to be ok. I connected it up to my trailer last night and eventually got all the bits and bobs (indicators, brake, lights etc) working.
I was out with the trailer today and there is a problem with the indicators, let me explain. When you put an indicator on (left or right) you see the wee green arrow on the dash flash for a very brief moment and then nothing. If you switch off the indicator and then put it on straight away it goes on fine. If you leave it longer than about 20 or 30 seconds to switch it on after the quick flash it doesn't work and you have to switch it off and straight back on again.
Same for both sides and hazard lights.
Any thoughts?
Dave
Old Jul 23, 2010 | 08:02 PM
waynefrst235's Avatar
waynefrst235
Sounds to me like the flasher unit needs changing. I vaguely remember a car with this fault at work and that was the fault
cheers Wayne
Old Jul 23, 2010 | 08:13 PM
taycoss's Avatar
taycoss
Did you fit a bypass relay?
Old Jul 23, 2010 | 09:42 PM
davey_b's Avatar
davey_b
No, just wired it in direct to the wires on the nearside of the boot.
Old Jul 23, 2010 | 11:27 PM
taycoss's Avatar
taycoss
most modern cars require a bypass relay wired in for the trailer lights.
Old Jul 24, 2010 | 01:24 AM
davey_b's Avatar
davey_b
It came with one of those buzzer things that you're supposed to put on these days that go off when you put the indicator on. I didn't really want the racket so I didn't put that on but now I'm wondering if that has a bypass relay in it...
Old Jul 24, 2010 | 10:16 AM
taycoss's Avatar
taycoss
if its a square box with 7 terminals then that will be the relay unit bud,they usualy have a buzzer in them too.
Old Jul 24, 2010 | 11:00 AM
davey_b's Avatar
davey_b
Have a look at this thread: https://passionford.com/forum/genera...ar-wiring.html
I've got the wee buzzer thing but no relay that is in the other picture in this thread. Do you think I need to get hold of one? I wonder if it might be built into the buzzer?
pabloXR
Sep 21, 2015 12:42 PM
Rammer46
Sep 18, 2015 08:31 AM
Cossikev
Sep 13, 2015 02:00 PM
The Enigma
Sep 12, 2015 10:12 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
