Mental wheel wobble!!! Please help
Old Jul 19, 2010 | 07:05 PM
FiestaStroud's Avatar
FiestaStroud
Default Mental wheel wobble!!! Please help
Firstly, how do i put pictures on here?!?!?!
Secondly, the big problem...
I bought an 88 escort 3 door estate with a 1600 8v engine from an xr2i,
when i got it the shocks were proper knackered so i changed them over with some i got off a H reg escort rs turbo but now when the car gets to 30mph i have such bad wheel wobble that the front end shakes!!! Strangely enough though if i take it out of gear and roll at 30 its not so bad.
I am a novice with a few mates that know odds and soda but we all pretty stumped at this one.
Tracking been done, and its not the wheel bearing, even had wheels balanced again to check!
Looking at her she is squatting on the front end and we all agree the camber seems out, but A.) i have no idea if the camber can be changed on the front end and B.) no garage i have asked is sure either!!!
This is my project car but typically i have hit a stumbling block already!
Any help would be greatly appreciated as i wanna keep her, despite calls to get rid from the missis and friends that dont like a challenge!!!!!!!!
Cheers for reading
Stroud
Old Jul 19, 2010 | 07:16 PM
FiestaStroud
Mwahahahahahaha. Done that one. I think!!!
FiestaStroud
Yeah, picture works, so just the brain numbing wheel wobble.
Cheers all
Old Jul 19, 2010 | 07:20 PM
adam151082's Avatar
adam151082
is the wheels tight?
Old Jul 19, 2010 | 07:24 PM
mrjenrst's Avatar
mrjenrst
sounds like you've fucked something up while changing the shock's. Bottom arm ok?
Old Jul 19, 2010 | 09:22 PM
boy-racer-1's Avatar
boy-racer-1
id say track control arm bushes, check see if they look worn or are worn
Old Jul 20, 2010 | 10:08 AM
FiestaStroud
so if i get new bottom arms will it sit better? like i said as you look at it front on it looks like you got a horse sat on the bonnet!!! if you get me.
cheers for the ideas though
will get checked out
any more? lol
P.S yes the wheels are tight!!!
Old Jul 20, 2010 | 12:40 PM
boy-racer-1
wel id say its about the only thing i can see causing it other then steering rack/pinion problems have you checked thats all tight? and make sure the shocks and dampers you bought if second hand arent collapsed/ f*ck*d, im not an expert on mk4's so i couldnt say for certain, go on feoc-uk.com haz on there knows mk4 escorts inside out and will probably know what problem you have
Old Jul 20, 2010 | 12:48 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
If youre unsure on this problem then get professional help, you can never be too careful esp with steering/braking etc,
Failing that, book it for a MOT and see what it fails on!
IainRS1700T
Sep 25, 2015 06:44 AM
pabloXR
Sep 21, 2015 12:42 PM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
