yb turbo wiring
Old Jul 15, 2010 | 08:45 PM
oldfordfella's Avatar
oldfordfella
Default yb turbo wiring
what wires do i need to connect to run a yb turbo ecu in a project car?
Old Jul 15, 2010 | 09:09 PM
studabear's Avatar
studabear
4 on the cossie loom plug
permanent live
switched live
fuel pump
rev counter
Oh and the earths on the engine bay loom
This is after you've plugged everything into the engine loom
Old Jul 16, 2010 | 07:57 AM
martysmartie's Avatar
martysmartie
What he said ^^ plus all the sensor connections.
Martin
Old Jul 16, 2010 | 10:11 AM
manoj's Avatar
manoj
this might help mate.
WIRE COLOUR/S Function
Red/ Blue (Permanent +ve) (Thick Wire)
or 2 black wires on a 3 Door Engine loom
Black (Ignition +ve) (Thick Wire)
Black/ Red (Fuel Pump Feed) (Thick Wire)
Green (Rev Counter Trigger)
Brown/ White (Temperature Sender)
Brown/ Green (Oil Pressure Sender)
Brown/ Red (Engine Management warning light) - not required, unless connecting to a 3dr loom.
L8 Engine Loom.
ground = brown
battery = red or red/blue
ignition switch = black
fuel pump = black/red
rev counter = green
The brown/green wire is not required as it is for the fault light relay on the L1 or the air con on the L8.
thanks,
Manoj
Old Jul 16, 2010 | 07:17 PM
oldfordfella
thanks guys, hopefully workshop should be getting noisy tomorrow
Old Jul 17, 2010 | 07:28 PM
oldfordfella
ok, still no luck changed the loom and the ecu and the f****r still wont start. i cant get a spark antone got any suggestions ?
Old Jul 20, 2010 | 02:20 PM
martysmartie
The fuel pump should prime when the ECU is powered up an (An exception to this is if the car is hot sometimes it will not prime) If not this is a good clue that a signal has not been received from the CPS thus you would also have no spark as well.
Also is it running a YB? In other words do you have the correct trigger wheel it should have 4 lugs, anything else and it won't work.
Martin
Old Jul 21, 2010 | 07:30 PM
oldfordfella
hi,fuel pump runs on ignition & i have a 4 lug trigger wheel. one thing that does seem odd is that the coil is showing a constant 12volt discharge not the usual 50000 ! ive orderd new crank & phase sensors plus ignition module and coil but i cant understand why they should of failed when the engine ran in the sapphire, trial by substitution seems a bit of a cop out though !!
jeff.
Old Jul 22, 2010 | 04:24 PM
martysmartie
If the pump primes then a signal is being received from CPS so that is working, check the ignition amp is connected ok, you should also have +12V at the back wire on the coil when ignition is switched on. You can't really measure the output of the coil as this is many thousand of volts using a meter etc, you don't have an output at coil (Or a good one) otherwise you would have a spark, did you measure elsewhere?
Martin
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Cosnada
Aug 27, 2015 09:15 AM
muz
Aug 16, 2015 12:57 PM
turbobill
Aug 1, 2015 08:55 PM
