Mk4 Escort Ignition lock
Old Jun 24, 2010 | 09:20 PM
Dod RS's Avatar
Dod RS
Back to the Old School
Default Mk4 Escort Ignition lock
My Escorts ignition lock is ferked. No key will open it or even fit in, I've gotten a Fiesta steering lock and removed the lock from the barrel but the Escort setup seems different. Will it work and if so, how do I remove the Escort lock?
Old Oct 19, 2010 | 10:16 PM
Dod RS's Avatar
Dod RS
Ok, I've sourced the proper ignition barrel but how do I remove the old one from its housing?
Old Oct 20, 2010 | 07:49 AM
There is a sprung clip bit that pops out from the lock and engages with a slot in the barrel surround push this in and then you can release the lock mechanism and draw it out, with no key though may involve drilling guts of lock out and a bit of brute force before you can remove it.
JoeyBoyden
Jan 4, 2024 02:36 PM
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
