Cossie keeps eating
Old Oct 26, 2003 | 07:48 AM
Alvyn's Avatar
Alvyn
Default Cossie keeps eating
PLUGS!! M8'S GOT STAGE 3 2 W/D SAFF HE RUNS IT ON CHAMPION 57C'S HE HAS DONE ABOUT 600 MILES(HE DOES LIKE TO RAG IT ABOUT) AND HAS HAD TO CHANGE THE PLUGS 3 TIMESNOT JUST 1 PLUG WITH NO TIP BUT 3 EVERY TIME)SO HE'S A BIT WORRIED WHETHER THE PLUGS ARE NO GOOD FOR HIS CAR OR WHETHER SOMETING ELSE IS CAUSING IT!ANY SUGGESTION I COULD PASS ON TO HIM?
I USE 57C IN MINE WITH NO PROBLEMS THOU!
Old Oct 26, 2003 | 10:00 AM
Danny B's Avatar
Danny B
get the injectors cleaned, that might help.
Old Oct 26, 2003 | 12:21 PM
CossieEdd's Avatar
CossieEdd
My first 2wd Sapph used to eat a plug almost every time I drove it hard.
In the end it looks like the head had been skimmed far, far too much and it was therefore running quite high compression and perhaps I ran a touch too much boost also, so every time it was held flat in 4th & 5th it would just get hot and blow the plug apart.
Sounds like his car needs sorting, but at least it's the plugs that are the weak link and are blowing - if he was running NGK 9's the plugs would probably be fine but something more serious might fail
Edd
Old Oct 27, 2003 | 01:52 AM
Stu @ M Developments's Avatar
PassionFords Creator
Are the tips actually coming off mate?
Old Oct 27, 2003 | 05:56 AM
Alvyn's Avatar
Alvyn
Default tips
Stu,yes m8! it depends on how hard he's driven it if not about 1/2 @ least!as said above this is his 3rd set in a short amount of miles!Ive told him not to drive(hard till he sorts it) as next time it could be alot worse than spark plugs!CAR HAS GOT ABOUT 150 COMPRESSION ON ALL 4 CYLINDERS|(No3 HAS 145) if that helps @ all! boost is set @ 22psi!
FOR ALL HELP
Old Oct 27, 2003 | 11:10 AM
Its gotta be lean and dettonating mate
Get it to a pro please, and fast.
He is INCREDIBLY lucky not to have killed it already!!
Old Oct 27, 2003 | 11:50 AM
Alvyn's Avatar
Alvyn
HAVE TOLD HIM! ITS UP TO HIM IF HE TAKES IT ON BOARD!!
CHEERS AGAIN!!!
Old Oct 27, 2003 | 05:24 PM
No probs mate
Old Nov 2, 2003 | 08:54 PM
dave cos4x4's Avatar
dave cos4x4
My tip came off and fooked my piston!
Rebuild time then!
Dave.
Old Nov 3, 2003 | 11:15 PM
Toe Knee's Avatar
Toe Knee
If the tips have come off hows he cleaned the metal bits out of the combustion chamber spec as its been a few times now
Old Nov 5, 2003 | 07:35 AM
Alvyn's Avatar
Alvyn
HE'S HAS HAD IT SORTED NOW WITH NO VISABLE SIGNS OF DAMAGE! (IT WAS RUNNING 1.5 ON TICK OVER)REGARDING THE TIPS HE MUST BE 1 LUCKY FCUKER!
Old Nov 18, 2003 | 11:42 AM
Smit's Avatar
Smit
The 60ft Launch King
ditto Dave
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
