Injection to Carb Conversion 2.8 Cologne in P100 Pick up
Old 19-06-2010 | 07:08 PM
The Angry Spider's Avatar
The Angry Spider
Default Injection to Carb Conversion 2.8 Cologne in P100 Pick up
Hi, I've come back to the blue oval having just got a G reg P100 pick up.
It's got an XR4i 2.8i lump but I think the fuel pump's just died and that's a good enough excuse to swap to carb -
I'm not that technically minded but can bolt sh*t together!
What do I need and from what to make it work?
I know I'll obviously need an inlet manifold and carb but what will fit it?
Mechanical fuel pump and push rod but from what?
I think the fuel tank'll be ok (Maybe not though?)
Manual choke kit
Anything else I obviously need?
Also, where's good to source the parts these days?
Thanks in advance -
Old 19-06-2010 | 08:33 PM
Just use the stuff from the likes of a mk2 granada carby model, these were auto choke so even easier, no cable to bugger about with, these bits are becoming hard to find so look on ebay, local papers, sierra shack etc.
Tank can be used without any problem, as external pump anyway.
mk3ste
17-10-2021 11:09 AM
07-10-2015 01:56 PM
sridgett
01-10-2015 08:30 PM
XR4
Ford XR Range
01-10-2015 01:46 PM
Orion_Gav
29-09-2015 05:50 PM
