st170 brake disc sizes.
Old Jun 14, 2010 | 10:02 AM
homer j's Avatar
homer j
Default st170 brake disc sizes.
Hi all,
can anyone tell me the dimensions for front and rear brake discs on a focus st170? I'm after the actual disc diameter as well as disc thickness. I've had a quick search about but so far have come up with nothing.
cheeRS
Tom
Old Jun 14, 2010 | 01:31 PM
ST170 front is 300mm, height 44mm, thickness 24mm(new), replace at 22mm
ST170 rear is 280mm, height 33mm, thickness 10mm(new), replace at 9mm.
Hope this helps,
Old Jun 14, 2010 | 06:36 PM
homer j's Avatar
homer j
cheers for the reply mate,
Tom
Old Mar 6, 2014 | 02:30 PM
Chrisfrs's Avatar
Chrisfrs
Is the thickness of the hub part 24mm? I know its an old post so BUMP
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
