Sapphire Cosworth Alternator Keyway?
Ladies and Gents,
I'm just refurbing the alternator and power steering drive pulleys on a 1990 Sapphire RS Cosworth 4x4 and have noticed that there is a keyway in the alternator shaft, but I cannot find any key steel that used to (maybe) live in there?
My question is:
Why is the keyway there if it is not used and is the keyway steel fitted to your car/from the factory? It's more of a keyway divet than a groove on my alternator.
Thanks,
Alex
My question is:
Thanks,
Alex
Most have the keyways cut to take a woodruff key, but some designs of pulley don't need keying as they don't slip like some do, if there's no groove in the pulley wheel it will be ok.
You can always count of "tabetha" to reply! Many thanks indeed.
My thinking exactly, but my pulley does have a keyway? However, I saw no key upon dis-assembly?
Could just pop to my local engineering supplier and try to fit a woodruff key?
Can anybody else comment?
Thanks in advance,
Alex
Thanks in advance,
Alex
all the ribbed type pullys never had a woodruff key but allways had the groove just save dpn tooling when they were made ive rebuilt numerous engines and never come across one
hope this helps
hope this helps
fella has it been re conditioned before most of the people who do it dont bother to put them back in even bosch go to a local reconditioner they will have woodruff keys as long as u do the nut up tight it wont cause u no trouble any way fella i been doin it like that for many years
Thanks for the replies chaps, most helpful - I thought your reasons may well be the case. As far as I am aware it has not been re-built.
The vehicle is an early car and so does not have the single serpentine belt, but the 2x toothed belts that drive the alternator.
Right, I'll pop into town tomorrow after work and see if I can source a woodruff key in order to attempt a real nice pukka job, if not then I'll just bolt her back together. If anything, the hole on one side of the rotating mass resulting from the lack of a woodruff key will provide an imbalance in the assembly and since I'm re-building the pulley system as it keeps eating its belts it can only help if I do get one in there.
Thanks guys, really appreciate your views.
Alex
Alex
3dr cossie
11
21-12-2015 03:38 PM
lukeeboy149
22-08-2015 04:29 PM
