Mondeo assistance
Old May 27, 2010 | 09:58 AM
rammer's Avatar
rammer
Default Mondeo assistance
Can anyone please advise me with a problem on a Forf Mondeo 1995 TD
whenever I start the car cold or hot the Radiator cooling fans start up, the weather can be -10 and its still the same,
any ideas please,
Old May 27, 2010 | 10:10 AM
percybigun's Avatar
percybigun
Twistin me melon man
do they start then turn off? mine sometimes does that
Old May 27, 2010 | 10:59 AM
rammer's Avatar
rammer
No They run continuos, not sure how to tackle the problem,
Old May 27, 2010 | 11:43 AM
percybigun's Avatar
percybigun
i dont know the proper fix, all i can say is check the wiring loom, plugs, sensor etc.
another fix is run the wires to a switch on the dash and turn them on/off manually
Old May 27, 2010 | 12:25 PM
martysmartie's Avatar
martysmartie
Not sure on the early ones if the fan was ECU controlled or not, if so could be EMS has detected a fault and put fans on.
More likely though they are switch controlled due to age, so first find the fan switch, this will be in the radiator or the thermostat housing, unplug the electrical connector, if fans still stay on it shows the relay is jammed normally a "tap" on it will unjam.
If the fans continue however this points to a faulty fan switch which is unlikely though.
I certainly would not rewire to a switch though this means you would have to switch on/off manually when they were needed and if you don't then your in trouble, hence why it is a automated system to start with, not to mention you are only "Working around" the problem rather than fixing it.
Martin
Old May 27, 2010 | 03:59 PM
rammer's Avatar
rammer
Hi Martin
Many thanks for the your quick response, I will check this out at the w/end when I have more time, I am sure your answer is the correct one, thanks again
George
Old May 27, 2010 | 05:21 PM
The fans on the petrol ones are certainly ecu controlled, on my old 94 reg 2L ghia, as said though if on all the time on petrol at least it has logged a major fault, that hasn't been corrected/fixed, it could be as simple as the ecu temp sender, if it loses reading this puts the fans on continuous as a safegaurd.
Old May 27, 2010 | 05:36 PM
Fiddy's Avatar
Fiddy
My money would be on fan switch or temp sender. as phil says, you could wire your fans to a switch on the dash, then your in control of them, and can switch them on/off when necessary.
Old May 27, 2010 | 07:08 PM
rammer's Avatar
rammer
thank you to all the respnses so far certainly gives me some idea of what to look for now, will let you know what the developements are
thanks again
Rammer
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
stevecfrst1
Sep 30, 2015 05:18 AM
The Enigma
Sep 29, 2015 10:31 AM
