cigerette lighter not working
Old May 26, 2010 | 09:09 AM
nthesx's Avatar
nthesx
Default cigerette lighter not working
Morning all
my cigerette lighter/power socket for some unknown reason has no power going to it,which means i am without the use of my satnav,and a trip to devon from northampton just doesnt appeal without it.Does anyone know what the fuse is for this,and is the fuse box in the engine bay the main central fuse box?
The car is a 2004 mondeo zetec 2.0tdci
also after haveing a fault code and replacing the part does the code need to be wiped,or can it be wiped just by disconecting the battery.
regards
nigel
Old May 26, 2010 | 11:43 AM
Not 100% sure but think the codes clear after a set amount of cold starts after problem has been corrected.
Old May 26, 2010 | 12:19 PM
martysmartie's Avatar
martysmartie
Fuse will be in the passenger fuse box and has a fuse diagram on the back of the glovebox generally speaking, think it's fuse 68 should be 15A, there is even a tool provided in the box for removal. I would think once a faulty part is replaced it will clear the associated fault code on next boot of the ECU.
Martin
Old May 26, 2010 | 12:27 PM
Kverna's Avatar
Kverna
Virgin-popper
My cigarettelighter is also out of function on my 2001 mondeo. Will be checking this as well, thanks
Old May 26, 2010 | 12:51 PM
**caz**'s Avatar
**caz**
Does it still stand that if the cig lighter goes that is the same fuse for interior light and stereo?
Old May 27, 2010 | 12:43 PM
martysmartie
Don't think so all cars I have come across have a dedicated fuse protecting the cigarette lighter and a "Battery Control fuse" that protects the interior lights, clock etc.
Martin
Old May 28, 2010 | 03:19 PM
nthesx's Avatar
nthesx
thanks for the replys guys
ok,found the fuses behind the glove box,which brings me to my next question.How do i remove the glove box to gain access to the fuses it looks as if you unclip it at the sides then give it a gentle tug it should pull out,like most i have come across,or not,well mine dont wanna at least,so am i missing something?
thanx in advance
regards
nigel
Old May 28, 2010 | 06:29 PM
martysmartie
Theres a stay on the left hand side which pushes to the right so can be removed when glove box drops, you have to push both sides of glovebox in at the same time this will give enough clearance on the sides for the rubber stops and so glovebox drops down.
Martin
Old Jun 29, 2010 | 02:25 PM
nthesx's Avatar
nthesx
ok, i can get the glove box to drop down,ive released the damper strut but it still doesnt come down enough for any great amount of access,so how do i get it off the hinges?with any real force just seems they are gonna to break.
regards
nigel
Old Jun 29, 2010 | 05:41 PM
martysmartie
There is normally one stay on the left hand side which pushes aside and can then be removed. The glovebox has two rubber stops both sides if you squeeze each side simultaneously these blocks will clear the dash and the glove box will touch the floor.
Martin
JK12
33
Apr 26, 2021 12:09 PM
jaysoc1
Aug 20, 2015 08:18 PM
