Factory CO setting 2wd saff cossie
Hi all what should the CO reading on a standard 2wd Saff Cossie be? 1-2% is on the slam panel is this correct? Should i set it to 1.5% when warm? Sorry if i sound stupid, i'm getting it hooked up to a gas ananyser next week and want it right for the test and also have to nurse it a bit on start up. Was told in another thread this could be the problem. Cheers
Officially it should be 1.5%. I always had mine running at 2.5 - 3% at idle, engine warm.
The engine is considered to be warm if the electric fans have started and stopped twice.
09-10-2015 07:38 PM
adam151082
11-08-2015 04:50 PM
