Cosworth Rear Suspension
Old Mar 18, 2004 | 07:25 PM
Default Cosworth Rear Suspension
Does anyone know if the rear beam, trailing arms and what looks to be 9" rear diff from a Granada Cosworth will fit onto the back of my 2wd sapphire cosworth ? According to the guy on the parts dept at my local Ford dealer he reckons the beam is the same part number so should fit striaght on but he doesnt know if the trailing arms and diff would be compatible.
Old Mar 18, 2004 | 07:54 PM
swerv's Avatar
swerv
i cant see a granada cosworth having a 9 inch diff
why are looking at doing this , just for the diff or are you building one from scratch??
Old Mar 19, 2004 | 07:37 PM
Basically, the diff on my sapphire is on its way out and i had a Granada Cosworth that i broke up but ive still got the complete rear suspension set up. My idea was to blast and powder coat the granny beam and arms, rebuild the diff which physically measures 9" (does this mean that the granny has a 9" diff or is it just a coincidence that the casing is that size?) and then swop the whole lot with over at weekend. What do you reckon ?
Old Mar 19, 2004 | 08:57 PM
swerv's Avatar
swerv
the 9inch diff is refering to the internals , a granada cos diff will also have a different ratio(not 100%sure on this though).
put a shout out to zoo on the main board as they more about diffs and will be able to tell you 100%.
but your granny dont have a 9 inch diff
Old Mar 20, 2004 | 09:35 AM
markk's Avatar
markk
the granny rear beam is the same as 2wd cos , the diff however is the same size as te 2wd cos 7.5" but the cwp ratio is 3.36:1 iirc !!
Old Mar 20, 2004 | 07:38 PM
Guinnless's Avatar
Guinnless
Nah 24v diffs are 3.64.
Same as 2wd Cossie.
Old Mar 21, 2004 | 11:58 AM
markk's Avatar
markk
r u sure cause they were all automatics ???
Oct 9, 2015 07:38 PM
TrevCos
Aug 17, 2015 09:08 PM
Aug 14, 2015 07:29 AM
dal3door
Aug 13, 2015 06:55 AM
Old ford
Jul 31, 2015 06:50 AM
