Rover zr indicator fuse blowing
A mate has a problem with a rover and just wondered if any one here noes any thing about them, Basicaly if indicating right the fuse blows and u loose ignition and the car cuts out, but is fine if indicating left
cheers
cheers
Then it's almost certain the live for the right indicator has a leak to earth causing the short. Not sure on that car where alarm wiring is for indicators most likely to be spliced into the lives if it's not done by an electronic module so I would start at the indicator stalk and go from there.
Martin
Martin
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
The Enigma
12-09-2015 10:12 PM
