Why o why won't it start
Old May 17, 2010 | 03:53 PM
liddon21's Avatar
liddon21
Default Why o why won't it start
Hi All,
I know another issue with starting the car. But all the posts i read dont seem to sound like my problem so here it goes.
When i turn the key the engine turns over for about 1 sec. Then it just makes a whine like noise. like a blowing groan noise. bit hard to explain lol.
It started the other day but would usually start on 2nd or 3rd attempt but now it aint going any where. It works if i get a push start.
I have also noticed a loud knocking noise start about the same time coming from the chargecooler water pump. But then goes away and the pump appears to be working. Related or coinsedance ?
HHHEEEELLLPPPPP
Old May 17, 2010 | 04:05 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Would help if we knew what car it was
Steve
Old May 17, 2010 | 04:18 PM
Physio's Avatar
Physio
Starter motor perhaps?
Old May 17, 2010 | 04:29 PM
liddon21's Avatar
liddon21
Zvh 2.0 mfi.
Old May 17, 2010 | 05:21 PM
cossie legend's Avatar
cossie legend
Its probably the starter motor not engaging properly or else teeth damaged on the flywheel.
Old May 17, 2010 | 05:35 PM
pompy1's Avatar
pompy1
I agree, starter motor. An air cooled adjustment tool normaly helps !! "Hammer"
Old May 17, 2010 | 06:07 PM
liddon21's Avatar
liddon21
Thanks guys will take a look after work. Hope it is a simple fix. Only new starter motor I seen is 220 on burton. Ouch
Old May 17, 2010 | 06:26 PM
Try ebay, bet it's under £50.
Old May 20, 2010 | 09:53 PM
liddon21's Avatar
liddon21
i tried the hammer method and it did work for a day. so i think im going to take it off and give it a good clean. fingers crossed. cheers guys
Old May 20, 2010 | 10:12 PM
botters's Avatar
botters
competant bodger
new starters are around £50 from most motor factors if you are or have a mate who is in the trade
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
Marino
Sep 12, 2015 11:10 AM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
