knocking or clicking on full lock
Old May 14, 2010 | 05:44 PM
95 fiesta si's Avatar
95 fiesta si
Default knocking or clicking on full lock
Well after putting in a complete new n\s driveshaft and 2 new wishbones, iam getting a knocking sound on full lock both left and right going forwards and when reversing but only from the n\s which has had the new driveshaft.....what could it be, its not popping out the gearbox like the old one was, but certainly doesnt sound right, the wheels arnt catching the strut either or rubbing. Only started doing this after about 10 miles driving on the new driveshaft
Old May 14, 2010 | 06:10 PM
phatford's Avatar
phatford
does it sound like beatboxing
Old May 14, 2010 | 06:32 PM
95 fiesta si
seems to knock at about the speed of a full turn of the road wheel
wonder if its the o\s driveshaft but its sounds like its from the n\s.
heard all sorts of things, wheel bearings, top suspension mounts, broken spring etc etc
driving in a straight line and breaking seems fine, its only when turning going forward or in reverse
Old May 14, 2010 | 06:35 PM
RichieST's Avatar
RichieST
Definately sounds like a cv joint!
Old May 14, 2010 | 06:40 PM
95 fiesta si
well its a brand new complete driveshaft including cv joint on the n\s only done like 10 miles, could it be the o/s defo sounds like the n\s the noise is coming from though
feels unstable like the wheels loose when going around roundabouts, ive checked the wheel bolts and there all fine, wonder if its a wheel bearing ?
Old May 14, 2010 | 06:44 PM
RichieST's Avatar
RichieST
Only way to be for sure is to get someone to stand outside the car and listen as you drive on full lock.
Old May 14, 2010 | 06:47 PM
95 fiesta si
might try that in a min then.
Old May 14, 2010 | 07:43 PM
95 fiesta si
well my mates just poped over and weve had it jacked up, wheels are stable but he says theres alot of play up and down on the strut leg so blaming the top strut mounts.
Old May 14, 2010 | 07:49 PM
jammerrs's Avatar
jammerrs
may be a long shot but my mums car had something simular to this and it was rust on the brake disc, well the mounting part of the disc not where the pads are.......caould be worth a look
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
steve.rst
Oct 3, 2015 08:52 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
rsturbo27
Sep 5, 2015 05:08 PM
