setting 4x4 idle speed
Old May 13, 2010 | 12:04 AM
ASHCOSSIE's Avatar
ASHCOSSIE
Default setting 4x4 idle speed
how do u set it up and where is the adjuster
cheers
Old May 13, 2010 | 12:36 AM
botters's Avatar
botters
competant bodger
its a flat head screw on the underneath of the throttle body, its a pain to get to but not the end of the world i would screw it a little at a time with a rev in between turns to allow it to settle
Old May 13, 2010 | 01:53 PM
Just make sure the engine is at full temp and all electrics(other than engine) are off.
The screw can be got to ok, using a stubby screwdriver.
Old May 13, 2010 | 08:15 PM
ASHCOSSIE's Avatar
ASHCOSSIE
And just to check, i adjust with or without idle control valve pluged in ?
cheers
Old May 13, 2010 | 08:26 PM
KSA-Cossie's Avatar
KSA-Cossie
Once up to temperature disconnect iscv set then reconnect.
Old May 13, 2010 | 08:41 PM
ASHCOSSIE's Avatar
ASHCOSSIE
cheers mate, its only had a idle prob since fitting a bailys breather, is it a common problem, it just sits at about 1600 rpm now, all i can think is it had a air leak from the vacume that went to the original breather
cheers
Sheepdisease
Aug 30, 2015 09:11 PM
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
JoeyBoyden
Aug 18, 2015 05:56 PM
Zoggon
Aug 10, 2015 10:39 AM
