L8 ECU fault finding help
Old May 1, 2010 | 11:48 AM
gaz3678's Avatar
gaz3678
Default L8 ECU fault finding help
About 4-5 years ago i downloaded (from PF) a quick help sheet for checking sensor values at the ECU plug. It was the most valuable piece of A4 paper I have ever had and now that i need it again I can't find it.
I am sure it was put together by one of the tuners but I can not for the life of me remeber which one. Please Help!!!!!!!!
Ads
Old May 1, 2010 | 12:38 PM
jon@work's Avatar
jon@work
this one?
BASIC FAULT FINDING GUIDE FOR COSSIE ECUS
NOTE: Some of these results can be affected by an alarm system or immobilizer. I have assumed the car has a 2.5 bar/3.0 bar map sensor.
If SECS monitor is fitted, unplug it! (A faulty monitor or incorrectly fitted can cause engine not to run)
1) Ensure ignition is OFF.
2) Remove rear of ecu plug cover and insert plug back into ecu.
3) Turn ignition back on (do not start engine)
4) MAIN POWER CHECK: Check for DC voltage of at least 11.5V between ecu pins 19 and 20.
5) REFERENCE CHECK: Check for DC voltage of around 4.8 to 5.2V between pins 11 and 30.
6) MAP SENSOR CHECK: Check for DC voltage of approx 1.8 to 2.5V between pins 11 and 15.
7) THROTTLE CLOSED:
4x4: Check for DC voltage less than 0.5V between pins 11 and 17.
2WD: Check for DC voltage greater than 4.5V between pins 11 and 17.
8) THROTTLE FULLY OPEN:
4x4: Check for DC voltage greater than 4.5V between pins 11 and 17.
2WD: check for DC voltage less than 0.5V between pins 11 and 17.
9) Turn ignition off, unplug ecu, and turn ignition back on (don’t forget immobilizer if fitted)
10) CRANK SENSOR: Check resistance between pins 3 and 4 between 300 and 1200 ohms.
11) CRANK SENSOR: Check AC voltage on pins 3 and 4 while cranking engine - should be at
least 2V.
11) PHASE SENSOR: Check resistance between pins 5 and 23 between 300 and 1200 ohms.
12) PHASE SENSOR: Check AC voltage on pins 5 and 23 while cranking engine - should be at
least 1.5 - 2V.
12) INJECTOR: Check resistance from pins 18 to 20 should be 2 to 5 ohms.
13) INJECTOR: Check resistance from pins 35 to 20 should be 2 to 5 ohms.
14) INJECTOR: Check resistance from pins 33 to 20 should be 2 to 5 ohms.
15) INJECTOR: Check resistance from pins 32 to 20 should be 2 to 5 ohms.
NOTE: INJECTOR TESTS MAY NEED MAIN RELAY ENERGISED ON L1 and L6 ecus (link pins 1 and 10 first)
16) IGNITION TRIGGER: Read voltage between pins 24 and 25, should be at least 4.5V.
17) IGNITION TEST: BEWARE DANGEROUS VOLTAGES ON PLUG/COIL LEADS.
Quickly link pins 24 and 25 on and off this will FIRE the ignition coil. Rotate dizzy by moving car in gear to point rotor arm at one plug lead and remove spark plug (earthing it on chassis or engine) to see spark. Try for each plug in turn. Or remove king lead at dizzy and place end within 1 centimetre of earth to see a big spark.
18) Place a temporary wire link from pin 1 to pin 10 (energises ecu power relay) - you should hear a click.
19) Quickly link pins 19 to 28 to test fuel pump runs.
20) COOLANT TEMP: Check resistance pins 29 and 11 for 800 ohms to 5000 ohms (depends on temp)
21) CHARGE TEMP: Check resistance pins 31 and 11 for 800 ohms to 5000 ohms (depends on temp)
Unplug the ecu and turn the ignition on. If the fuel pump runs the relay has been wired to run permanently or the relay is jammed.
However, if the pump is running continuously, this WILL NOT stop the car from starting.
Some chips don’t drive the fuel pump relay output properly as this is used for other features like ALS etc.... (PECTEL/AHMED chips mainly). In these situations, the pump is rewired to run continuously.
If however, the pump is wired correctly and working properly, if it runs continuously when the ecu is plugged in only, then the ECU and/or chip may have failed.
The pump is ok to run continuously
Old May 1, 2010 | 12:42 PM
jon@work's Avatar
jon@work
deleted - another fault finding guide, but it doesn't cut-and-paste from Excel
Old May 2, 2010 | 01:32 PM
gaz3678's Avatar
gaz3678
HERO
That is exactly the one .
FYI for a 3 bar map sensor 1.7 to 1.8 Volts is the norm, 2.5 Volts is correct for a standard 2 bar. This caught me out when my MAP sensor packed up a few years ago as I saw 2.5 - 2.8 and thought it was OK......
Cheers again,
Ads
JK12
33
Apr 26, 2021 12:09 PM
RSmark84
Sep 13, 2015 01:29 PM
JESX12
Sep 4, 2015 09:16 AM
