ford focus 1.6 clutch "advice needed"
Old Apr 25, 2010 | 07:05 PM
focusblack's Avatar
focusblack
Default ford focus 1.6 clutch "advice needed"
hi there my focus clutch is slipping and need to replace the clutch have ordered a clutch kit with the slave cylinder going to do it myself . because ive not done it before i would like to no if you can encounter any problems or anything a need to look out for or replace when doing so ,
ANY advice would be much aprecciated
thanks shane
Old Apr 26, 2010 | 12:28 PM
martysmartie's Avatar
martysmartie
A clutch alignment tool or you can make your own with a broom handle etc to make sure clutch is aligned with pressure plate, the kit should include the pressure plate, driven plate and the release bearing as well. With the slave cylinder just make sure it's bleed properly after as this also shares the same fluid as brakes.
Martin
Old Apr 26, 2010 | 06:43 PM
focusblack's Avatar
focusblack
thanks for that martin much appreciated
Ford Focus RS Parts for Sale.
Aug 18, 2015 05:25 PM
taylora1409
Aug 12, 2015 12:06 PM
