focus battery light
Old Apr 22, 2010 | 02:05 PM
john-v6tt's Avatar
john-v6tt
Default focus battery light
have a y plate focus 1.4. the problem is when i start it the battery light goes out, then after around 30 secs the battery light comes back on and stays on. any one had this problem before? any info or help would be great.
cheeRS john
Old Apr 22, 2010 | 07:36 PM
martysmartie's Avatar
martysmartie
These use a "Smart Charge" system meaning it's ECU controlled so may well be ECU related but check the 3 pin plug on the alternator first for broken wires as these are prone for getting broken.
Martin
Old Apr 22, 2010 | 08:29 PM
cabriolet's Avatar
cabriolet
alternator does this but as said check the wiring first not normally ecu
Old Apr 26, 2010 | 09:03 AM
john-v6tt's Avatar
john-v6tt
cheers guys, will check all the wires today. if no broken wires, just changs the alternator?
cheeRS john
Old Apr 26, 2010 | 12:31 PM
martysmartie
If not plug, could be alternator but it's worth testing otherwise you could have wasted expense on a new one.
Martin
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
xr_craig
Aug 7, 2015 06:00 PM
